  • SN95 4.6L Mustang Tech
SCT SF3 Rev Limiter
  • Thread starter Thread starter 2gtrs
  • Start date Start date Sep 6, 2009
2gtrs
  • Sep 6, 2009
On the SCT SF3 tuner, is setting a specific rev limit amount a simple process of just keying in the rev limit rpm, or do you need a custom program? For a particular reason, I would like to use it to set a rev limit under 3000 rpms on certain occasions, and wondering the simplicity and process of this option. Thank you in advance.
P
peepeeskillz
171
texas
Sep 6, 2009
  • Sep 6, 2009
im not sure about an sf3. mine supposed to be an x3 but it was manufactured before a certain date so it's now considered an sf3. but anyways on mine yes u can just go and adjust to that easy, it will retune it when you do, but it only takes less than 2 minutes to do. but im not sure how low it goes, ive never tried to set it below 6000.
T
tonytaylor85
126
Augusta GA
Sep 6, 2009
  • Sep 6, 2009
It is an option. There is a "neutral" (neu) limit which is the limit when you are stopped. I have mine at 3000 and mess with people at redlights- and i think it will go down to 2500. It also helps with the launch if you need it. The "drive" (drv) limit is self explanatory.
P
peepeeskillz
171
texas
Sep 7, 2009
  • Sep 7, 2009
if you have a manual transmission you don't want to set it that low though, because i think it just wont let your engine go over whatever you set the neutral rev limit to.
T
tonytaylor85
126
Augusta GA
Sep 7, 2009
  • Sep 7, 2009
The canned tunes from SCT are like that but my custom tune works like i described. I'd forgotten about that. My car is a 5 speed and having the two step rev limiter is one less thing to concentrate on when launching on street tires. It also gets funny looks out of Prius drivers at redlights.
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Z
Bama SCT x3 tune settings
  • Zaner
  • Jan 24, 2020
2K
SN95 4.6L Mustang Tech Jan 24, 2020
Zaner
Z
Digital Tuning BAMA SCT ETC.
  • MarineDeuce
  • Jul 12, 2019
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jul 12, 2019
MarineDeuce
99 Mustang GT High Rev On Cold Start
  • OneSick99GT
  • Nov 20, 2018
10K
SN95 4.6L Mustang Tech Nov 29, 2018
OneSick99GT
Strange Engine?
  • Jimmy K jam
  • Dec 24, 2017
SN95 4.6L Mustang Tech Dec 28, 2017
mogs01gt
