  • SN95 4.6L Mustang Tech
SCT Tuning.....
  • Thread starter Thread starter 32valves
  • Start date Start date Aug 28, 2007
32valves
42
Philadelphia, PA
Aug 28, 2007
  • Aug 28, 2007
I gues I just got the full PRP moved from another car to my Mach1. I was wondering if anyone has any input on things that I should change that are simple basics or things to NEVER touch. I dont have enought mods to ned a dyno tune so right now I'd just like to tweak the timing some. But I'm not sure what settings are safe on the Mod v4 4.6
EDIT: Also what is a 2 step rev limiter? My last car didn't support this.
BlueGT4.6
9
Stratford, CT
Aug 28, 2007
  • Aug 28, 2007
a 2-step rev limiter is for drag race launches. You can dial that into a specific RPM where you launch from. When it's dialed in with the tuner, you can floor the clutch and gas, and the RPM will remain at your 'launch RPM.' Once the car starts rolling (.1 mph), it disengages and goes back to normal. That way you don't have to watch your tach and the light tree at the same time. I think that's what it's called anyway...
32valves
42
Philadelphia, PA
Aug 29, 2007
  • Aug 29, 2007
Well I played with it yesterday and it turns my neutral rev limit into my full time rev limit. Any Ideas what i did wrong?
BennyBlown2v
1,233
Carmel, INdiana
Aug 29, 2007
  • Aug 29, 2007
You didn't set it in the tune, you have to go into advantage 3 and load the two step value file, otherwise it doesn't know what to do.
So when you say you "guess" you have the PRP....do you, or do you just have an Xcal2??
32valves
42
Philadelphia, PA
Aug 29, 2007
  • Aug 29, 2007
Sorry I ment "Just got".
Ryan@SCT helepd me with the load values. If all went right then tonight I'll be trying her out on the way home.
2000fordstanggt
404
Westland, MI
Aug 29, 2007
  • Aug 29, 2007
ive seen in the manual for the xcal 2 a program to adjust settings on your computer screen rather than on the tuner screen. i cant find that anywhere on the sct site. anyone have a link?
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Aug 30, 2007
  • Aug 30, 2007
get a wideband 02 sensor and do some datalogging of the a/f ratio. adjust it to 13.0 under load. you aren't going to be able to increase the timing too much as the car is already tuned for premium gas. but you should be able to add another 2 degrees total timing. there really isn't anything else that's going to get you more power.
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
O
injectors keeping up?
  • optionizerSS
  • Apr 4, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
optionizerSS
O
96 Cobra IMRC delete, dyno’d
  • Gunmonkey
  • Aug 29, 2024
  • SVT Tech Forum
SVT Tech Forum Nov 7, 2024
Gunmonkey
J
Engine LOSS OF POWER AT 4,000 RPM.
  • Jarhead67
  • Nov 17, 2024
3K
Fox 5.0 Mustang Tech Jan 25, 2025
Jarhead67
J
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
