  • 2005 - 2009 Specific Tech
Second gear clunk
  • Thread starter Thread starter frankie_b11
  • Start date Start date Feb 11, 2010
F
frankie_b11
20
  • Feb 11, 2010
Hey Gang,
I live in MI and I have noticed this mostly when the car is cold, when I shift form 1st to 2nd before I release the clutch I get a clunk.
Once the car warms up it is not really noticeable.
It happened before and after I changed the transmission fluid.
any ideas?
F
frankie_b11
20
  • Feb 12, 2010
Anyone, Bueller.
NastyStang113
1,567
Florida
Feb 12, 2010
  • Feb 12, 2010
Factory driveshaft? It's a two piece with a slip joint in the middle, kind of normal for it to make a lot of noise especially on the 1-2 shift.
Sparty92
430
Detroit Burbs
Feb 14, 2010
  • Feb 14, 2010
Hi from Michigan!
Are you saying it's a clunk in the transmission when you shift into 2nd? Or is it after you are in gear?
There is a TSB about a crunchy 1-2, and 2-3 shift...when cold. I've been debating on whether I have it or not.
TSB 09-19-17
Where are you in Michigan? Maybe we can meet up and compare our cars!
ZeroLink
26
TX
Feb 15, 2010
  • Feb 15, 2010
I have a clunk when I shift between any gear, hot or cold. I thought it was my driveshaft so I replaced it with a 1 piece unit. It did help a little but while I was under the car down at the rearend, I jiggled the pinion back and forth with the driveshaft out. I got about 3/4 inch of play and it made the exact clunking sound. So, could it be excessive backlash as it is in my case? There are a few others here that have had the same it issues and it turned out to be backlash. Unfortunately who ever did my 4.10s really screwed up.
'08GTcaRED
330
Victorville, CA
Feb 15, 2010
  • Feb 15, 2010
Backlash isnt just from gears. it is also from your u-joints. if you kept the old u-joints from your old shaft, on either end, prob should replace them...
F
frankie_b11
20
  • Feb 15, 2010
Sparty92 said:
Hi from Michigan!
TSB 09-19-17
it is from 1-2 and 2-3 like you mentioned.
I live in Grand Rapids
What is TSB? Sorry for a stupid question.
F
frankie_b11
20
  • Feb 15, 2010
OK,
I figured out the TSB, this is for 2007-2008 mustangs. Mine is an 06 but does the exact thing the TSB talks about.
I just replaced the tranny fluid with synthetic so when they fix it I will lose like 40 bucks.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
