stangGT97
MineralMan said:25HP is more of an increase than the '01 Bullitt had over the '01 GT.
well dont forget, the Bullitt had a lot of other things going for it. Better suspension, upgraded brakes, special interior trim pieces, some exterior mods, and the bullitt manifold is good for gains across the powerband (peak numbers arent everything). I think they are a very solid upgrade from the GT, especially when you factor in the price of upgrading your stock GT with all of the parts that the Bullitt has on it.
Then the Mach1 is another step above the GT, with similar suspension and brakes as the Bullitt but an engine that is in a class of its own. For the record, the Mach 1 4V 4.6 is not just a N/A terminator motor... a few things that come to mind is the 10:1 compression, shaker induction system, different heads, and aluminum block. It's a completely unique motor.
http://www.mach1registry.com/Specs/Specs.htm
