Self-disconnecting window regulators
  • Thread starter Thread starter CurlyA6
  • Start date Start date Jan 6, 2012
CurlyA6
47
Pacific Grove, CA
Jan 6, 2012
  • Jan 6, 2012
I was finally making progress putting the interior into my '68 Coupe restoration, but am now stuck. I can't button up the doors until I sort out the interior workings, and I could use some advice.
I bought new regulators when the body came out of paint ten years ago, and asked a glass shop to install them when they put in the new front and rear windscreens. I had to button up the car quickly to trailer it, and I now live across the country from the glass shop. Either the reproduction regulators (sadly, from the now deceased Paddock) were not the best, or the glass shop did shoddy work. Either way, the car was sealed for a February drag across the northern half of America, and the windows rarely rolled up and down during the car's ten years of reassembly in the garage.
But now that the car is almost road ready, here's the problem. When I roll the windows up or down, the ball shaped studs at the end of the regulator arms occasionally pop out of the plastic rollers in the window or door tracks. It seems like the regulator arms themselves are shaped incorrectly, and as the window moves up or down the bend in the arms tends to pull the arm away from the roller track.
The passenger side is not as bad, only the rear regulator arm pops out of the roller in the track at the bottom of the window glass. The driver's side is much harder to roll (more resistance) and both the regulator arm at the rear bottom of the window glass AND the short arm that rolls in a track bolted to the rear, inner door structure pop out.
I'm thinking I should bend the arms toward their respective tracks. My plan is to allow them to pop out, then with the arm free grab the center of the "X" of the regulator and bend each arm end toward it's track. I think this will apply positive pressure to keep the ball fitting at the end of the regulator arm seated in the plastic roller, and the roller in the track.
My question then: is this a good idea/recommended fix? Or will bending the arms mess up the geometry of the regulator making it even harder to roll the windows up and down? Am I missing parts or fittings that keep the ball fitting seated in the rollers?
Any suggestions for keeping the regulator arms in the rollers in their tracks would be most appreciated. Once I fix this disconnect problem and hunt down some annoying door rattles I can put on the door panels and move on to seat upholstery.
Thanks.
iskwezm
4,159
20
79
Rowland Heights,California
Jan 6, 2012
  • Jan 6, 2012
the plastic rollers should have a clip that lock onto the regulator.Is the clip still there or is the roller broken?
mtaqua
345
  • Jan 6, 2012
I had the same problems as I had changed some things up in the rear windows. I did two things to solve the problem. One was reshape the clips to apply more pressure, needle nose vise grips and some patience. 2nd was I rebent the arms to slightly different angles to apply less pressure to the rollers. However I just had one pop off and now I have to take the seat out again (I'm not sure if it popped or came off the track, but the window won't roll up now).
CurlyA6
47
Pacific Grove, CA
Jan 7, 2012
  • Jan 7, 2012
iskwezem: nope, no clips that I can see. The ball end fitting appears to be swedged or welded onto the regulator arm, and the fitting simply pops into the plastic roller, which stays in the track. I'll look at the diagrams and see if there are clips that I'm missing...that might be part of the problem, no?
CurlyA6
47
Pacific Grove, CA
Jan 7, 2012
  • Jan 7, 2012
mtaqua: first off, sweet Harrier photo.
I'll look into to clips, and thanks to your advice, if they need it I'll now know they can be reshaped. I'll try rebending the arms a bit too, but then leave the panels off for a bit to see if the window mechanisms stay together. Thanks.
horseballz
824
Las Vegas, NV
Jan 7, 2012
  • Jan 7, 2012
Check these:
http://shop.autocraftinvestments.com/index.php?p=product&id=146340&parent=2930
http://shop.autocraftinvestments.com/index.php?p=product&id=146121&parent=2930
As I have not addressed/repaired the windows on my 68 yet, I'm not sure what part goes where or what is for what year, I've just been looking at catalogues in hope of being prepared when the time comes to tackle it.
HTH,
Gene
horseballz
824
Las Vegas, NV
Jan 7, 2012
  • Jan 7, 2012
Also check this and ensuing pages:
http://www.cjponyparts.com/Category.aspx?ss=&c=10110340&sb=&sd=&pgnum=1&pgsize=&filter=
The ones with the clips are listed to fit a 68, but so are the ones with the rivets? Let us know what you discover.
HTH, Good Luck,
Gene
mtaqua
345
  • Jan 7, 2012
Yep, if no clips on the plastic rollers they will not stay on. The fitting that the roller slides on has a recess that the clip rides in keeping the roller on. The rollers are cheap, I'd buy extra in case you break a couple in the fitting process.
CurlyA6
47
Pacific Grove, CA
Jan 8, 2012
  • Jan 8, 2012
Hmmmmm, it seems the folks at the glass shop installed the ball-type regulator and plastic rollers but no clips at all, and I've never noticed those parts were missing. Thanks to all for helping me figure this out. I'll order new rollers and clips (to make sure they match) and replace soonest, then come back and tell you all how it worked out.
Thanks.
CurlyA6
47
Pacific Grove, CA
Jan 9, 2012
#10
  • Jan 9, 2012
  • #10
Yep, mystery solved. Turns out the new regulators I bought ten years ago are the type with the ball fittings at the ends of the arms; the type that calls for rollers with clips. I suspect the old regulators were the type that the rollers rivet to the regulator arms. So, the folks at the glass shop likely reused the rivet type rollers (but just the plastic parts, not the rivets) by setting them in the window tracks and then pressing the new regulator arms' ball fittings into them. Sigh. Thanks to Gene for the photos that cleared up the mystery. New clip-style rollers are on the way and will likely fix the problem.
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
Interior and Upholstery How to replace door window regulator arm roller
  • AnthonyA1234
  • Sep 17, 2024
Fox 5.0 Mustang Tech Sep 19, 2024
limp
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
