F FriscoSteve New Member Apr 1, 2010 36 0 0 Apr 27, 2010 #1 Apr 27, 2010 #1 Will replacing the MAF correct error code 26 on KOEO?
liljoe07 5 Year Member Feb 18, 2009 1,622 363 124 Cartersville,Ga Apr 28, 2010 #2 Apr 28, 2010 #2 Not if its a wiring issue, or another problem.
F FriscoSteve New Member Apr 1, 2010 36 0 0 Apr 28, 2010 #3 Apr 28, 2010 #3 I tested all four wires on the MAF connector. All checked out accordingly. Thanks for responding Joe. I was hoping to hear from you. Thoughts on what else it might be?
liljoe07 5 Year Member Feb 18, 2009 1,622 363 124 Cartersville,Ga Apr 28, 2010 #4 Apr 28, 2010 #4 I had the code mixed up, a MAF sensor may fix it if the wires all tested good. Whats the voltage at the MAF signal wire with the engine at Idle? Should be between .2v and 1.5v
