Im in a dillema right now. I have a 69 Grande Coupe with a 393 stroker and Art Carr AOD w/ 9" rear. I had some major major overhaul ideas of completely changing the combo but now Im considering selling and getting a 70 fastback. There is a local guy selling a 70 Mach1 (shell basically) and using it as my gueini pig for my new combo. If I sell the coupe, how much should I ask for it???
Here are the specs....
69 Grande Coupe
Engine:
393 stroker 445.8hp and 500.1ft/lbs (less than 500 miles)
Milodon Race pan w/ pickup
750dp Holley
Full MSD ignition
Aeromotive Carb Pump
8AN Fuel Lines
Aeromotive Filter
Aeromotive Regulator
Tranny:
Art Carr AOD
Art Carr Torque Converter
Prostick shifter
B&M Tranny Cooler
Rear End:
Fresh built 9"
Auburn Limited Slip
Richmond 3.89 Gears
Brakes:
All stock non power drums
Interior:
Deluxe 69 Black Interior (almost perfect)
Autometer Gauges
-5" Phantom Tach
-5" Phantom Electric Speedo
-2 5/8" Phantom Chebby Fuel gauge (due to fuel cell sender)
-2 5/8" Phantom H20 Temp
Mallory Gauges
- Oil Pressure
- Volts
- Vaccuum
Brand New floorpans
Cooling:
Afco Race Radiator
Flex a Lite Electric Fan
Suspenion:
Fresh Rebuilt front end
Eibach Progressive Rate Springs
Misc:
Fuel Cell
14x7 American Racing Wheels (new rear tires and full size spare)
1970 bolt in glass
Relocated Battery
Hooker Comp Headers
2 Chamber Flows
3" exhaust
Things it needs:
Radio
Speakers
Console (if you want to run one)
Export Brace
Extra Stuff:
69 Glue in glass
Stock A/C Equipment
Stock Radiator
Stock Shifter
Maybe some other stuff...the car has little bits of rust in the normal places... I have treated the most of it with Por 15. The engine bay might be shaved and repainted (haven't started but it was planned on) and I plan on getting teh car repainted (Maaco or somtheing similar) before it gets sold. Any suggestions on selling or price to ask? I have over $20,000 into the car and have the recipts for all the big things. I ahve recipts in atleast $13k in work and parts. Im really looking to build a showcar so I figure a FB is the way to go on that. The new drivetrain is going to be SICK.
Plans for new car:
5.4L DOHC motor
Navigator Heads
Twin Turbos (not sure of size yet)
TKO tranny (maybe T56 if they can handle the power)
Full 2002 GT wiring harness
Full 2002 GT interior
12pt Cage
Complete tube chassis
MII Front suspension w/ 2" Drop spindles
Ladder Bar Rear suspension
Built 9" w/ 33 spline axles
Mini-tubbed wheel wells
17x9 TTII's w/ 275 front tires
17x11 TTII's w/ 335 rear tires
16Gal Fuel Cell
Dual A1000 Pumps
My goal is for a new car running 900-1000hp (flywheel) on pump gas in an old stang. It will be a total weekend cruiser and show car...
69 Grande Coupe
Engine:
750dp Holley
Full MSD ignition
8AN Fuel Lines
Aeromotive Filter
Tranny:
Art Carr AOD
Prostick shifter
B&M Tranny Cooler
Rear End:
Fresh built 9"
Auburn Limited Slip
Richmond 3.89 Gears
Brakes:
Interior:
Autometer Gauges
-5" Phantom Tach
Mallory Gauges
- Oil Pressure
- Volts
- Vaccuum
Brand New floorpans
Cooling:
Afco Race Radiator
Suspenion:
Misc:
Fuel Cell
1970 bolt in glass
Relocated Battery
Hooker Comp Headers
2 Chamber Flows
3" exhaust
Things it needs:
Radio
Speakers
Export Brace
Extra Stuff:
69 Glue in glass
Stock A/C Equipment
Stock Radiator
Stock Shifter
Plans for new car:
5.4L DOHC motor
Navigator Heads
12pt Cage
16Gal Fuel Cell
Dual A1000 Pumps
And $500 for front brakes? Aw, you know you'll want a nice set of 13" Baers.... and what about rear brakes? More Baer, right? Thats gotta be more like $2300 for brakes alone. You get my point...
