I figured that since the engines been apart it'd be a good idea to do an oil change. Now normally it's just a chance to spend a little quality time with the car,check for leaks of any kind and give the underside a once over. While i was at Canadian Tire grabbing supplies i saw that Quaker State makes a line of oils for different applications. They have a 5w30 for "regular" driving,10w30 for "heavy duty" apps like towing and such,then a 15w30 for "high performance" driving. I've always used 5w30 cause that's what Ford recommends so i loaded up and headed home. BUT,while i'm under the car,waiting for the oil to completely drain i got thinking about the QS ratings. At first it seemed weird to me to make a heavier weight oil for performance applications. By all sense,the lighter weight should free up more hp from less drag,which is what a "high performance" car owner wants. So why would 15w30 be better? Here's my best guess. A heavier weight oil maintains a better "cushion" between the metal surfaces at higher rpm. BUT,looking at the ratings ?w30 they should all be the same viscosity from ? temp to 30 degrees and as we know an engine runs a little warmer than 30 degrees C. Typical oil temps for most cars without an oil cooler will be within 30 degrees of the engine temp.(about 165F or 74C on a mustang) So wouldn't it make sense that all the oils will be the same viscosity at 74C,or are there still some differences?
I also remember seeing that alot of race teams use a single weight oil in their engines(seems to usually be a 40 or 50 weight). Is this for the same reason,to maintain a more stable oil film on all the bearing surfaces when running at constant high rpm? I think we all know that mineral oils versus synthetic is not the issue here(no question that synthetic is better) but i'm really wondering if someone,like myself,who drives their car hard would be better with the 15w30 oil to protect the engine? Keeping in mind that i don't winter drive it so a light oil is not crucial for easy starting.
What's everyone's opinion's on the subject? Am i on the right track with my thoughts on the 15 vs 5 w30 ? Any experienced engine guys who want to speak up please do as i'm really wondering what your using and why?
