GodAmGT00
dude496 said:And to clarify on the "buzzing noise"...it happens anytime i am about half throttle and up. The reason why i'd put money on it being the torque convertor is that it happens in drive, and also in park....and the noise is definatly coming from the transmission. Now buzzing is probably the wrong word to call it, but cant think of a better word
Okay..
Would you classify it as a "chatter," or a high-pitched rattle?? Maybe the pump was installed wrong?? Are you able to get underneath the car at all?? Can you tell if all of the plugs/harnesses are in good shape??
What about the Torque Converter Inspection plate?? I wonder if the harmonic vibrations from the car being on/revved could cause this noise?? Sounds foolish, but I've seen things like that happen before.
Has the shifting improved at all since all of this madness had started??
JT
