serpentine belt
Notchbck88
hey guys since i put the underdrive pulleys in my car whenever i start it up the belt will scream for a couple seconds afterwards and when i give it alot of gas or make turns it will sometimes scream too anone know what i can do to fix this? the belt is new it came with the pulleys
Look closely at the tensioner - there is a small arrow that points to an area marked "range". The arrow should be about in the middle of the "range". My guess is that the belt is a bit too long, and the tensioner isn't putting enough tension on the belt causing it to slip on start up. You may need a different length (slightly shorter) belt. How long is the belt they supplied? What is the part number on the belt?
agreed, the belt is too loose
cool i think thats what the problem is going to be i went and looked at it and the belt does seem to be loose do you think the stock belt will fit on there or should i get a new one?
thanks
