Set me straight on braided fuel line and plumbing.
9 Deuce GT
550
Geneva, NY
I read all the posts in a search, but am still a little confused on a few things. I am researching swapping to braided stainless lines on my '92 GT. How do the lines connect to the fuel filter? I have seen the spring lock ends that are sold, but they have a barbed end on them which appears to be for a nylon hose. How would you attach this to the braided line with AN fittings?
Also, how do you attach the lines to the body along the floor pan? Are there brackets that are made that would rivet into the stock locations?
they make a quick connect hose for the barbed fittings run your filter connecter then quick connect hose to a barbed to -6 or what ever fitting for the size line your going to use then a female -6 to -6 line fitting and run the line.they make rubber coated line clamps to hook it to the floorpan and stuff. look on the summitracing.com website for these fittings and line
