Ok I knew this was gonna happen, but Ive got 4 problems with the car I just bought.
1. A/C compressor cycles on/off 4/6 seconds respectivley. A/C works fine, it does this anytime the air system is on. ie heat, defrost, vent, a/c, etc.
2. Theres a hanging idle....it likes to hang at 1350 and slowly drop to 750 after several seconds. I verified this with the digital readout trick. It does this anytime whether the ac is on or not.
3. Theres a hesitation around 2000-2500rpms under about half throttle. A full throttle run through the gears doesnt have this problem. Its almost more of a bucking than hesitation.
4. The fuel gage wont read full. I can fill it up to about 3/4 of a tank. The fuel light comes on at E and I can put about 11 gallons in when that happens. Using the digital guages feature, it will still sweep to full and then back down to E. Is this just a matter of pulling the needle off and ajusting it to read full?
The car is a 2002 gt with 3,620 miles on it. The motor is unknown, it may be the original/ it may not. The motor was out of the car for about 3 years, anything I should check for?
It read full for the few seconds I had it on there and when the compressor would cut off the pressure would drop.
