  • SN95 4.6L Mustang Tech
shifter problem
  • Thread starter Thread starter mustangcam
  • Start date Start date May 9, 2006
M
mustangcam
70
Pensacola, Florida
May 9, 2006
  • May 9, 2006
so i just installed the new mgw shifter in the cobra about a week ago and yesterday i started to notice a slight grinding noise from the same area . it loudest right as each gear catches as i shift to it. the wierd thing is that i can only notice it when my hand is touching the ball on the handle. so if i shift and then instantly let my hand off the handle i dont hear it. when installing the shifter i noticed there was a tiny slit in the inner dust boot. i dont know if that would cause this noise or not but does anyone have any ideas?
M
mustangcam
70
Pensacola, Florida
May 9, 2006
  • May 9, 2006
ok so i just took it for a longer ride with no radio or anything and the noise is noticeable even when i'm not touching the shifter handle but it gets louder when i touch it. someone's gotta have an idea.
Shiroelex
There's nothing worse than aut
728
Westland, MI
May 9, 2006
  • May 9, 2006
That noise is typical with most aftermarket shifters. What you need are those thick gaskets, that absorb most of the noise and vibrations revealed by the new shifter. I'm sure someone can come up with a link to one.
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
May 9, 2006
  • May 9, 2006
How about something like this from Steeda?
Shiroelex
728
Westland, MI
May 10, 2006
  • May 10, 2006
That's part of a 2 piece kit I saw somewhere. There was that gasket, and a fat gasket that went between the shifter and the transmission.
Pearl02
496
Kansas City
May 10, 2006
  • May 10, 2006
I also have some noise with my MGW. It's not that loud. Pearl02.
Dorsai
Connecticut
May 10, 2006
  • May 10, 2006
Mines as quiet as the original shifter was. I bought the gasket from MustangTuning instead of using the RTV. You could try reappling the RTV thicker this time, maybe you squeezed enough out to get metal on metal where the shifter sits on the trans ?
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
H
Transmission Help
  • Harman78
  • Feb 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 21, 2025
Harman78
H
