Shifter Question
  • Thread starter Thread starter 69Rcode_Mach1
  • Start date Start date Nov 7, 2005
69Rcode_Mach1
1,473
Salt Lake City, Utah
Nov 7, 2005
  • Nov 7, 2005
This is for you guys running the steeda Tri-Ax. How hard is it for you guys to get the thing into gear. For some reason sometimes I have to put all my strength into getting it in gear, and sometimes it will just go right in. Is this what is meant by the shifter being notchy that I kept hearing about with the Tri-Ax. Getting it into 5th gear isn't even possible half the time. When I get this thing on the road I don't want to have to spend 5 minutes at every light trying to get the tranny into gear.
T
tjm73
2,418
Rush, NY
Nov 7, 2005
  • Nov 7, 2005
Sounds more like a tranny problem than a shifter problem. Did it exhibit any difficulties with the stock shifter going into those gears??
69Rcode_Mach1
1,473
Nov 7, 2005
  • Nov 7, 2005
Nope, then again the thing was never driven with a stock shifter.
bubba-dough
1,044
Indiana
Nov 7, 2005
  • Nov 7, 2005
Or clutch problem??? But my B&M Ripper Pro was notchy as hell at first but after a few days it loosened up. But I still hate the thing and am going to put my Pro 5.0 back in.
T
tjm73
2,418
Rush, NY
Nov 7, 2005
  • Nov 7, 2005
Is the tranny new or rebuilt? I think 3rd and 5th use the same synchro. It could be bad.
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Nov 7, 2005
  • Nov 7, 2005
i have a tri-ax and it feels real notchy too. And ive had it for over a year. My transmission is a brand new WC. It has problems going into third, or i suck at it maybe. It sure seemed like it was easier to shifft with the stock shifter for some reason. Also sometimes when i go to pull it out of gear it kinda acts as if it the fork or shift rail was sticking or something. Maybe tri-ax's suck.
69Rcode_Mach1
1,473
Nov 7, 2005
  • Nov 7, 2005
I am beginning to regret the tri ax decision. The tranny is a rebuilt T-5z I got off of corral. I hope it eases up as it breaks in a little more. But yeah the original shifter never had this problem.
T
tjm73
2,418
Rush, NY
Nov 7, 2005
  • Nov 7, 2005
Well I have a Tri-Ax in my '90 GT that works flawlessly everytime in every gear and has for over 30,000 miles. I highly doubt the problem is the shifter. Mine is still a little notchy but not too bad. It's a trait of the shifter. I can shift fast enough that the syncho's can't match the gear shift speed with it and not miss a gear.
You should check this page out. Particularly the top 2 diagnosis boxes about 1/2 way down the page.
http://www.hanlonmotorsports.com/HanlonTIC.html
Umby
129
Atlanta, GA
Nov 7, 2005
  • Nov 7, 2005
Sounds like a cable problem to me
69Rcode_Mach1
1,473
Nov 7, 2005
#10
  • Nov 7, 2005
  • #10
It's a hydraulic clutch, and it is disengaging properly.
9
92notchback347
29
#11
  • Nov 9, 2005
  • #11
check to make sure the plastic cup, where the shifter rod rests in the tranny isnt worn out on one side?? My Tri-Ax works flawless, worth every penny!
FORCED2DV8
458
Grand Rapids MI
Nov 9, 2005
#12
  • Nov 9, 2005
  • #12
Mine worked really well, i had no problems. I had more issues with the stock shifter.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
