shifter question
  • Thread starter Thread starter stykthyn
  • Start date Start date Oct 15, 2008
stykthyn
5,232
2,652
223
gainesville
Oct 15, 2008
  • Oct 15, 2008
I finished up a t5 swap not too long ago and I am having problems with the shifter. the car is hard to put into gear which I am sure the cable has too much slack in it. I can deal with that and fix it. what's really bothering me is that when I push the shifter into 3rd the pivot ball at the base of the shifter handle will pop out and I have to come to a stop and literally unbolt the shifter handle and put it back in. is the salck cable causing this as well?
04gtboy
83
  • Oct 16, 2008
Is the plastiic sleeve for your shifter missing ?
stykthyn
5,232
2,652
223
gainesville
Oct 16, 2008
  • Oct 16, 2008
the what?
Vinnietbird
584
  • Oct 16, 2008
The ball on the bottom of the shifter fits into a plastic sleeve.If the cable is too loose,you can have shifting problems with that as well.
stykthyn
5,232
2,652
223
gainesville
Oct 16, 2008
  • Oct 16, 2008
I did not see a plastic sleeve. I will check to see if it fell out.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Oct 16, 2008
  • Oct 16, 2008
well if you still have the stock quadrant, which I'll assume you do, did you adjust it in order to tighten the clutch cable after installing the transmission?
If not, it's really simple, all you do is pull up on the cluth pedal (opposite than pressing it in to shift) with your hands until it pops. This disengages the gears on the stock quadrant and then by pressing the clutch back down or pressing it in, it engages the teeth to make the cable tighter.
If there is no pop, chances are the quadrant has been adjusted before like this and the quadrant is stripped where it needs to disengage the gears. You can look under there see the whole shabang with a flashlight and then disengage it another way as well.
Sorry if this didn't pertain or didn't help, but let me know if you have any more questions, and I'll see what I can do
04gtboy
83
  • Oct 16, 2008
Even if ur clutch isnt adjusted right ur shifter shouldnt do that ! You must be missing that sleeve . That might be causing your problems getting it in gear .
stykthyn
5,232
2,652
223
gainesville
Oct 16, 2008
  • Oct 16, 2008
I have a UPR triple hook quad. the cable is on the outermost hook and is still loose. it almost feels like the more I drive the looser it gets. I have an FWA that I am installing over the weekend so that should cure that.
the bushing is in the shift fork, but it is very worn on one side. so I am going by the dealership tomorrow to see if I can pick up another one. if they dont have one I guess I'll have to wait for 5.0resto to ship one to me. thanks for the help guys. I'll let you know how it goes.
stykthyn
5,232
2,652
223
gainesville
Oct 17, 2008
  • Oct 17, 2008
dealership does not have one in stock, but they can have it hear on Monday for $8.21
kind of pricey if you ask me, but the dealership is only 15 minutes away from me and it will be faster than 5.0resto.
for anyone that is interested the technical name for the plastic bushing is
Gear Shift Damper Bushing ford part# E3ZZ-7K453-A
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
P
Drivetrain Aod to T5 shifter Question
  • Piratemike
  • Apr 22, 2024
Fox 5.0 Mustang Tech Feb 25, 2025
Piratemike
P
