  • SN95 4.6L Mustang Tech
Shifting in the cold
  • Thread starter Thread starter NewbStang
  • Start date Start date Nov 14, 2004
N
NewbStang
213
  • Nov 14, 2004
Ive noticed whenever I first start driving I have trouble getting it into second...I either have to force it in or do it real slowly...once the car warms up it goes in smooth...Now that its been cold it's even ah rder toget to second when first starting...If I were to get a tri ax would it help allievate this or make it worse since its firmer?
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Nov 14, 2004
  • Nov 14, 2004
What i do before i drive away at the start of everyday,and after work after sitting all day,(hot day or cold day),i go through the gears about three times.The trans must let the fluid run through the gears.
And i've never had a grind,or any other symptoms that most expirience.
Oh!!And yes i have the 3650.
C
codyGT
365
Nebraska
Nov 14, 2004
  • Nov 14, 2004
My Camaro SS (T56) has the same problem. It is kind of weird though that my Dad's 98 S-10 with the five speed doesn't do this.
merc123
420
North GA
Nov 14, 2004
  • Nov 14, 2004
Take it to the dealer. There is a TSB out on it.
mustang70
2,445
San Diego
Nov 14, 2004
  • Nov 14, 2004
FWIW
I had the same problem with my wife's 91 Mazda. I changed over to a synthetic blend gear oil and never had a problem again. Of course, the fact that I was using Gear Tech oil to begin with probably didn't help matters.
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Nov 15, 2004
  • Nov 15, 2004
The TSB and/or switching trans fluid should help.
Switching to an aftermarket shifter won't solve this issue if it is related to the operating temperature of the transmission fluid (but a new shifter is STILL a good mod, so you might as well get one -heh).
Unfortunately, when the weather gets really cold outside, the trans fluid needs some time to "warm up" before shifting becomes smooth. There's no doubt that once the car reaches operating temp, the drivetrain responds much easier.
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Nov 15, 2004
  • Nov 15, 2004
when it warms up, the synchro's grip better and the dog-teeth will line up. mine grinds when i shift hard into second when cold. after thats it's fine.
03GreyMach1
15
  • Nov 15, 2004
You can try synthetic fluid. I tried Mobil 1 and only put in 3 liters. (less fluid from TSB)
I have read that Texco (Havoline) Dexron III is the best fluid to use.
It seems a little better but is still there (clunk/grind).
I will take it in for thr TSB after the winter.
As for a aftermarket shifter... don't do it until the dealer looks at your tranny.
The short throw shifter just amplifies the problem so don't give them any reason to not fix your transmission! (they would not look at mine with the Triax on!)
Good luck
N
NewbStang
213
  • Nov 16, 2004
I don't have a warranty so I prob will not be doing that....also what is the TSB
SRMobile
Trend Micro poster child
Jun 1, 2004
#10
  • Nov 16, 2004
  • #10
TSB: http://forums.modulardepot.com/showthread.php?s=&threadid=32640
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,079
224
Massachusetts
Nov 16, 2004
#11
  • Nov 16, 2004
  • #11
When you get a chance, read the 75+ page thread posted at the top of the forum on the 3650.
You are not alone
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
