thehueypilot said:I think I spotted the source of your overheating in your photos. Get rid of the filter your have spliced inline with your radiator hose. It not only cuts down on your flow (causing overheating) but could also break (plastic?) or blow off the ends of this plastic piece leaving you stranded or worse (engine failure). If a filter was that important to a cooling system Ford would have them in all their cars from the factory. IMHO
I don't personally like the plastic ones. The brass ones are the way to go IMO. The radiator filers are a nice item. Not all the casting flakes get removed by hot tanking/diping your motor. A lot of those flakes come out over time and clog yer radiator. If you keep up with the maintainance then you wont have a problem and your radiator will last forever.... practically.
I do agree that it would be a good idea to check/clean the filter.
