I don't, but it should be available at latemodelrestoration.com and the like. It is factory, but I added more to the face because the hub is smaller in diameter than the back side of the airbag wheel.Do you still have part number for momo hub. That plastic on column is factory ?
No problem. It brought it towards me an inch or so. I can't say for sure as I never measured.Did it move location of steering wheel? Thanks for all the help .
So those pics are an aftermarket wheel on an air bag column?It's a '92. I modified the hub because if you don't, it sits way forward. I used a dremel to bore the hub out a bit so it would sit back.
I've been considering doing a steering wheel since my air bag isn't connected, but most people say it doesn't work right on a 90 or newer column.
Does your horn work?
Thanks
