Short Hub & Quick Release
  • Thread starter Thread starter 1badhrc
  • Start date Start date Jun 5, 2016
  • 3
First Prev 2 of 3 Next Last
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Jun 11, 2016
#21
  • Jun 11, 2016
  • #21
Farrell5.0 said:
That is correct. They say it doesn't work simply because it doesn't slide down the shaft far enough out of the box. I bored it out with a dremel and used a nut to space the distance for the bolt that tightens the hub down. The horn would work if i spliced the wires but I haven't done so because of the quick release (which obviously isn't necessary), so I left the wires tucked in the hub cavity.
Thanks, I may give it a try.
Sounds fairly simple, especially since I have a buddy with a machine shop that could easily open up the bore.
The horn was my main concern and I've seen reproduction Ford Buttons for the horn.
1badhrc
46
#22
  • Jun 15, 2016
  • #22
1badhrc
46
#23
  • Jun 15, 2016
  • #23
Hub came in today . Gonna install tomorrow. I appreciate all the help .
Farrell5.0
Not sure what "DP" means, but know's he likes it!
353
299
104
Vancouver, WA
Jun 15, 2016
#24
  • Jun 15, 2016
  • #24
Not a problem. Let me know how it goes.
1badhrc
46
#25
  • Jun 15, 2016
  • #25
I will. What did you use to close the gap behind the hub if you don't mind me asking.
Farrell5.0
353
299
104
Vancouver, WA
Jun 15, 2016
#26
  • Jun 15, 2016
  • #26
You mean on the column cover? I bonded some acrylic to the face of the two halves, then did some filing and trimming and re-painting.
1badhrc
46
#27
  • Jun 15, 2016
  • #27
No there is about a 3/4 in. gap between hub & column cover on mine .
Farrell5.0
353
299
104
Vancouver, WA
Jun 15, 2016
#28
  • Jun 15, 2016
  • #28
Right, that's what I'm referring to. I'll go take a picture of the inside of mine to show you.
1badhrc
46
#29
  • Jun 15, 2016
  • #29
Thanks man. I can't tell you how much help you have been .
Farrell5.0
353
299
104
Vancouver, WA
Jun 15, 2016
#30
  • Jun 15, 2016
  • #30
I just glued an acrylic sheet to the front of the cover, then trimmed it from there.
Reactions: FoxMustangLvr
Farrell5.0
353
299
104
Vancouver, WA
Jun 15, 2016
#31
  • Jun 15, 2016
  • #31
Obviously it's a bit time consuming to do all the trimming and filing but it's worth it. Glue it on the inside like in the picture, and the outside as well, then you can file and sand it all down to look like it came that way from the factory.
1badhrc
46
#32
  • Jun 16, 2016
  • #32
After you modified hub did it slide all the way down steering shafts ? As it sits now steering wheel sits about 3in. further out.
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jun 16, 2016
#33
  • Jun 16, 2016
  • #33
Post a picture of what you have going on
1badhrc
46
#34
  • Jun 16, 2016
  • #34
Wish I could but I don't know how to post pics .
1badhrc
46
#35
  • Jun 16, 2016
  • #35
Gap
  • Media owner 1badhrc
  • Date added Jun 16, 2016
Is hub supposed to make contact with horn contacts ?
1badhrc
46
#36
  • Jun 16, 2016
  • #36
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jun 16, 2016
#37
  • Jun 16, 2016
  • #37
Look at his picture again, you can see his hub looks to be sitting against that plate. I'd venture a guess that you need to remove that connector. Other people are having to purchase a universal horn kit in order to get their horn working again on airbag cars.
Farrell5.0
353
299
104
Vancouver, WA
Jun 16, 2016
#38
  • Jun 16, 2016
  • #38
Honestly I don't remember if I butted it up against the contact or removed the contact. I'll check when I get home this afternoon.
1badhrc
46
#39
  • Jun 16, 2016
  • #39
I really appreciate it. You have been a great help .
1badhrc
46
#40
  • Jun 16, 2016
  • #40
I'm goin to have to modify hub for that . He mentioned having to do that . Just don't know how much I have to open hub.
  • 3
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
O
Suspension Extremely Quick / Light Steering
  • Okie
  • Oct 21, 2025
Fox 5.0 Mustang Tech Oct 22, 2025
AeroCoupe
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
