I was going to advance my E303 cam with mods similar to yours - but after playing with the timing, fuel pressure, etc... I am quite pleased with it dot-to-dot - it now has good low end pull with quick rev's and good power up to where I use it daily up to 5k RPM. I have 1.7's, Crane springs, 76mm C&L, underdrives, mild ported E7's, equal length shorties, Flowmasters, Ignition Solutions Plama Booster, hotter spark, 70mm MAC t/b, Edelbrock Performer 5.0, Kirban AFPR, 19lbs (soon to be 24lbs) injectors, 3.73's, Centerforce Dual Friction.... I have heard if you advance it 2 degrees you lower the upper end by 10hp and pick up on the low end - that is why I considered it - I like low end power - Now I am happy low and top end after lots of playing with adjustments.
