should i upgrade the injectors?
my mods are in the sig...four questions:
would my mods warrant bigger injectors? also what size injectors are needed for a 5-8psi supercharger? is the 190lph sufficient for one?
should i upgrade the fuel lines - fuel rails? thanks!
Yes you should, I am suprised the 19's are holding out. At least 24's if not 30's, a 190 will cut it but 255lph should be the choice "while your at it", and with a SC, your looking at least 36's. Fuel lines are marginal with the SC setup.
30's are an option, but often warm start issues go along with them..for what reason I'm not sure though. I run 24's with a 190 in the tank, and have no concears in regards to having enough fuel...I would expect these components to serve me well even with the increased need created by my nitrous use (will be running 75shot.)
