signs of a bad timing chain
cobra103
I have am 85 Mustang. I gave it a tune-up, it started and drove OK. Later on that day it was hard to start, I finally got it started. I got about a block away and then it cut off, couldn't get it back started. The firing order is right. I reset the timing, but the timing was way off, even using a timing light. Anyone have a clue or any suggestions drop me a line.
If the timing chain was bad the timing would bounce around. It is dificuilt to read the timing when you try and time it.
Do you have a solution, to why it's not starting. It's getting a spark and gas.
But it won't started.
What do you mean by hard to start? Did it turn over slowy, or did you have to spin it for a long time? I was gonna guess maybe your coil died, but you say you have spark. As for slop in the timing chain, you can see it if you pull the dist. cap and turn the motor in one direction, then the other. Some of this slop is in the cam gear/ dist. gears, but it can give you a rough idea if there is a big prob. Rotate the engine to TDC and see if the rotor is pointing at #1, or 180* off. That will tell you if it has jumped time or not.
:hail2: Excellent reply. Couldn't have said it better myself!! :nice:
