I've done it both ways. I would probably suggest pulling tranny with the motor. A 5/8" ratcheting wrench (for bell housing to engine bolts) is a real knuckle saver if you pull engine alone. A little trick I found that makes the pull easier (motor & tranny or just motor alone) is to jack the back of the car off the ground. Some might not like this because you have to scotch the front tires to keep car from moving around. I do not set the back of the car on jack stands, and would not suggest this because I'm one of those who is a little paranoid about pushing the car off the stands while jerking the hoist around pulling the motor. I leave my heavy duty floor jack under differential as I pull so if I do push or pull around too much the jack will move with the car. But it sure helps me when I do this right before hoisting engine out of engine bay. If you have the right equipment, i.e. heavy duty floor jack, engine hoist, and level concrete garage with plenty of room, and only do this right before pulling, this really works well. I have even pulled the motor straight up and pulled the car right out from under it by the floor jack. Doesn't help at all with putting engine back in, though.
I'm a newbie to stangnet. Lots of good info here. Hope ya'll don't think I'm a complete unsafe idiot because of the way I pull an engine. You do have to be careful and like I said, have good equipment and lots of room and be careful. If your like some rednecks I know (and I are one) and your using a limb of an oak tree on the side of a hill to pull your motor to replace it with the one you got your wife for Valentine's Day, I would not suggest this method. Just buy her some tickets to the stock car races instead.............
