Simple Question.
  • Thread starter Thread starter korsburn
  • Start date Start date Jul 7, 2005
korsburn
50
  • Jul 7, 2005
Im planning on changning out my drive shaft today after work and was just wondering what size the bolts were that hooked up the rear of the shaft to my rear end? I was told that i should get new ones when i change it out. And also what grade should i get? Thanks for any input you have.
DW5.0L
172
Florida
Jul 7, 2005
  • Jul 7, 2005
Your bolts should be fine. I think you'll need 12 or 14mm.
korsburn
50
  • Jul 7, 2005
oh, alright thanks man. That saves me some time and alittle bit of money.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jul 7, 2005
  • Jul 7, 2005
They are 12mm 12-point bolts, and I have reused mine several times now with no problems. You might want to have a drain pan handy under the rear of the transmission because some tranny fluid will drip from the tail shaft. Also, you might want some pb-blaster to help get those bolts looses, sometimes they have a lot of rust build up around them. Have fun.
woodyy24
290
illinois
Jul 7, 2005
  • Jul 7, 2005
yeah, you may need to have someone step on the brakes while you loosen them, they on there very tight. you may or may not need a drain pan, i didnt when i did mine, i just had the raer jacked up high enough that non of the fluid came out except for what was in the end of the driveshaft. you can reuse the bolts i have many times also.
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Jul 7, 2005
  • Jul 7, 2005
You can put the 12 mm box end of a boxwrench on the driveshaft bolts and then smack the end with a mallet. It needs to be the 5-7 pound deadblow mallet so it has some momentum. They should pop loose after 1-2 good whacks. With the transmission in park/gear and the ebrake set, the car shouldnt move.
vristang
4,933
101
124
Seattle
Jul 7, 2005
  • Jul 7, 2005
12mm box end wrench. I bought the longest one I could find. Then I hit it with a hammer. E-brake on, Trans in gear. I put all four corners of the car on jack stands. I don't fit under the car when only one end is jacked up.
I'm not fat, I'm just big boned.
I also hit the bolts with a hammer when installing them.
crazypete
Oct 22, 2004
930
Arlington, MA
Jul 7, 2005
  • Jul 7, 2005
Oh yeah, make sure you dont have a duuuuuuuh drooool moment like me and whack the bolts in the wrong direction
That was less than fun trying to free super torqued bolts.
HISSIN50
34
129
Jul 7, 2005
  • Jul 7, 2005
If not mentioned, hitting the bolts with some heat loosens the threadlock.
Be sure to threadlock the bolts again when reinstalling them. I use a 3/8" ratchet wrench and 12 pt 12mm socket.
slow93
406
#10
  • Jul 7, 2005
  • #10
man i gotta try hammer thing when i put mine back in...i took them out without a wrench.(vise-grip fingers!!)
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jul 7, 2005
#11
  • Jul 7, 2005
  • #11
Yes on both!
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
