simple question....
  • Thread starter Thread starter Roos
  • Start date Start date Oct 17, 2007
R
Roos
24
  • Oct 17, 2007
well...first off im REALLY new to the v8, mustang scene.....and my header is leaking at the head and i had the gasket replaced while is was under that one month warranty.....well brand new gasket and still have tick tick tick......any ideas?...how do i get rid of it....
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Oct 17, 2007
  • Oct 17, 2007
did you try and re torque the header bolts...could be a small leak at the flange to the H-pipe.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 18, 2007
  • Oct 18, 2007
Some of the aftermaket headers have individual flanges for each exhaust port. These type of headers tend to leak much more than headers with a one piece flange for all the exhaust ports on that side.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Oct 18, 2007
  • Oct 18, 2007
I've had the same problem again and again, but finally fixed the problem with a new header gasket (less than 20 bucks a pair) and a little bit of copper rtv (6-7 bucks). Was kinda skeptical at first, but no problems after 8,000 miles. Took a little time massaging the heads just enough to get the gaskets in, but other than that, a breeze.
87foxstang
Cromwell, CT
Oct 18, 2007
  • Oct 18, 2007
yea that copper rtv stuff works really good. When you tighten the header bolts, your going to want to drive the car a little bit and once its warm check them again, and retighten them if you have to
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 18, 2007
  • Oct 18, 2007
Roos - What type of headers do you have?
R
Roos
24
  • Oct 18, 2007
i have bbk headers....and it has a BRAD NEW gasket on it and when i left the shop it still ticked...and i would think they could get them tight...some one told me to use 2 gaskets?....any one heard of that?...
87foxstang
Cromwell, CT
Oct 18, 2007
  • Oct 18, 2007
i have never heard of that, but i wouldnt personally do it. I have the BBK shorties on my car and i had a header gasket blow on me about 2 weeks ago, so maybe the gaskets BBK supplies are junk I went with better metal ones, well not metal but i cant for the life of me think what they are called right now, it has been a long day, im sure someone will know what they are called. One side has a metal like finish on it, i thought they looked safer.
RYC CUKR
1,437
Orlando
Oct 18, 2007
  • Oct 18, 2007
For header gaskets I really like the dead soft aluminum style header gaskets.I have never had a problem with them leaking.
If you really want to pinpoint which primary the leak is coming from take a piece of 3/8" hose about 3' long and put one end to your ear, then run the other end around the header flange. You will really be able to hear where the leak is at. Also run it around where the ball and socket joint where the header and h pipe connect. Hopefully that will pinpoint where your leak is coming from.
R
Roos
24
#10
  • Oct 19, 2007
  • #10
you can tell it coming from the header...its LOUD and annoying....where could i get one of these "metal" gaskets.....2 try that
RYC CUKR
1,437
Orlando
Oct 20, 2007
#11
  • Oct 20, 2007
  • #11
http://store.summitracing.com/partd...&part=PHP-66014&N=700+-81085+115&autoview=sku
SuperStang83
1,693
Boyertown, Pa
Oct 20, 2007
#12
  • Oct 20, 2007
  • #12
I would just start loosening up the exhaust and retighten everything that you can if you have access to a lift. A lift makes doing this type of work so easy.
R
Roos
24
#13
  • Oct 20, 2007
  • #13
cool cool i will try them things and let every one know how it goes. thanx for the advice
R
Roos
24
#14
  • Jan 14, 2008
  • #14
back from the dead....so i found the leak, its the flange on the header its kinda broke ...i found it awhile a go but didnt have money to fix it but now i might so the question is will a shop fix that or would it be easier to get new headers?....
Mustang5L5
Mod Dude
Feb 18, 2001
43,358
18,105
224
Massachusetts
Jan 14, 2008
#15
  • Jan 14, 2008
  • #15
Prob easier just to get new headers
R
Roos
24
#16
  • Jan 14, 2008
  • #16
is there any better then others. whats the diff between long and short?..im kinda thinking long so then it would be easier to put the H pipe on?...what would b a good header/ h pipe combo?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 14, 2008
#17
  • Jan 14, 2008
  • #17
A machine shop can weld the flange and make the surface true.
Longtubes will cost more, and make a bit more bottom-mid range power.
They cost more and are not emissions legal if that is a concern.
H-pipe swaps or removals are easier, but installing longtubes and clutch installs will be more of a pain that short headers.
Longtubes sound better, in my opinion.
R
Roos
24
#18
  • Jan 14, 2008
  • #18
well after reading i don't have much of a choice, since i have and auto but i can get bbk header and h pipe for 350ish to the door and it would probly cost the price to get new SHINY ones....so i think thats what im gonna do ive been wanting an hpipe any ways
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
