My 93 GT has a nasty skip and loss of power when it is under a load. It happens when I get on it hard, when i try to give it gas under 2k, and sometimes up hill. I have been racking my brain for months now trying to fix this. So far I have tried the following:
New cap and rotor, new msd wires, new bosh platinum plugs, msd coil
checked the map and mas sensors and they are good.
retarded my timing back to stock(10) thinking it may have been to advanced
changed the fuel filter
upgraded to premium fuel
eliminated my high flow cats thinking they may have been plugged
The only mods i have on the car are cold air intake, msd 6al ignition, shorty heads, x-pipe and 3 chamber flow masters.
I just got a vacuum diagram so i will check for vacuum leaks or clogs.
Anyone have a similar problem and find the solution?
What do you guys think it could be?
a bad TPS sensor could cause this. My TPS was bad and would not show up on the code reader. Another thing I would do if I were you would be to get rid of those crappy bosch platinum plugs. MSD does not recommend them when using one of their boxes. Stick to autolites non platinum, good luck.
Oh yea fixed the problem. It was a bad TPS. Replaced all those parts and it turns out it was right in front of my face lol. Thanks for the advice Curse saved my ass. You ever need any help or anything let me know i will do my best.
