  • 1994 - 1995 Specific Tech
slight ping
  • Thread starter Thread starter 302fordracer
  • Start date Start date Jun 23, 2005
302fordracer
738
Vancouver, WA
Jun 23, 2005
  • Jun 23, 2005
I really dunno what to do here guys...I think I have fixed it cause it goes away for awhile and then it comes back...right now if it is sunny 70 degrees or hotter I get ping in the midrange (4k-4500) it is very slight so I must be getting close to getting rid of this thing but still it persists...I have recently had a dyno tune so the timing and a/f ratio are good, fuel filter is good, all new ignition, used seafoam, replaced act and ect sensors...I am at a loss...oh and btw I checked out the vacuum lines and it looked good but I will prolly replace those and the fuel pump soon enough... any ideas other than that???
302fordracer
738
Vancouver, WA
Jun 23, 2005
  • Jun 23, 2005
btw I can prolly get by with the way it is now cause it is very minor...just a little tick tick right in the middle of the powerband and then it is gone...but I would like it to be 100% ping free...
Blown94coupeGT
42
Byram, Mississippi
Jun 23, 2005
  • Jun 23, 2005
What type of plugs are u running? When is switched from Autolite 25's (stock plug) to the current 23's it helped a lot with pinging. I also switched to 89 octane. Do you have any ignition upgrades?
JJ95GTID
1,141
Phoenix, AZ
Jun 23, 2005
  • Jun 23, 2005
MAF wires clean? Are you using cheap gas like Flying J, Albertson's, Fred Meyer's, etc. If you are then try spending the extra .10/gal on Chevron gas. It is better and makes a difference. No pinging is good. Even a little pinging is going to bring down the engine's efficiency.
HISSIN50
34
129
Jun 23, 2005
  • Jun 23, 2005
what are your operating temps when it pings vs when it does not?
Good luck.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 23, 2005
  • Jun 23, 2005
Which condition makes it ping?
Medium load conditions
or
High load conditions (wot)
Later
Grady
302fordracer
738
Vancouver, WA
Jun 24, 2005
  • Jun 24, 2005
to ping the engine has to be under the greatest load I can give it...going up hill at wide open throttle on a warm (70 and up) day...I use 92 octane gas from 76 everytime and yes I have cleaned the maf sensor...I am running autolite 24's no ignition upgrades and the ignition is all brand new as stated before..
302fordracer
738
Vancouver, WA
Jun 24, 2005
  • Jun 24, 2005
just saw this chart in another thread and it got me wondering...if you check out my dyno numbers it is a safe bet I am right at or maybe even slightly over 285 horsepower at the crank...with this in mind are the 19 pound injectors at 38-42 psi fuel pressure just not doing the job??
(click on link and the chart is in post number 9 on that thread)
http://forums.stangnet.com/showthread.php?t=557707
SQUEEZE&STROKE
SOUTHERN CA
Jun 24, 2005
  • Jun 24, 2005
The Computers In The 94-95 Cars Are A Pain In The Ass. My Car Would Always Run Hot AND PING LIKE A MOFO EVEN With Just Simple Bolt Ons. I Tried Everything...all New Hoses, Radiator, Waterpump, Fan, And Nothing Worked. I Also Thought It Was A H/g But It Would Always Run Fine In The Evenings Or Early Mornings. Finally I Got An A9l Computer Conversion With Manual Fan Switch And It Never Ran Cooler, NEVER DETONATED OR PINGED AGAIN. Picked up A Few Tenths In The Quarter On The Motor And Almost A Full Second On The Unit. If You Want One Let Me Know...as You Can See From My Signature I Have One For Sale!
Scott_95GT
387
Sacramento
Jun 24, 2005
#10
  • Jun 24, 2005
  • #10
I cleaned my maf 2 weeks ago, and my pinging completly went away.
GRGT1994
1,034
#11
  • Jun 24, 2005
  • #11
You got a dyno tune and you still have pingning? What is the point of dyno tuning if they don't clear your pinging issue?
302fordracer
738
Vancouver, WA
Jun 24, 2005
#12
  • Jun 24, 2005
  • #12
It wasn't pinging before the dyno tune...the point of the tune was it was running wayyy rich and needed to be leaned out and since I already had the computer it was real cheap like 100 bucks..the pining came about just recently as the weather started getting over 70 everyday...
HISSIN50
34
129
Jun 24, 2005
#13
  • Jun 24, 2005
  • #13
How are your A/F ratios now? If this only happens during hotter ambient temps, I would wonder if the chambers are not a little dirty. It is strange that this came about after a dyno tune though. Will the shop touch up the burn for you for cheap?
Good luck.
302fordracer
738
Vancouver, WA
Jun 25, 2005
#14
  • Jun 25, 2005
  • #14
"touching up" the tune as you put it would cost me the same as a new tune...about another 100 bucks...see the tune is dirt cheap but I gotta pay for the dyno time...oh well if the above stated theory is correct and I need to clean my chambers that will be taken care of when I put on my gt-40 irons
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
F
Resolved Stumble issue upon acceleration (1987 GT)
  • FoxDude87
  • Sep 16, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Dec 3, 2024
FastDriver
M
  • mnky99
  • Sep 5, 2025
mnky99
M
A
Bank 1 misfire
  • austin21
  • Apr 29, 2024
4K
1996 - 2004 SN95 Mustang -General/Talk- May 6, 2024
austin21
A
