Slow Cranking
  • Thread starter Thread starter SyberSaint
  • Start date Start date Aug 4, 2010
SyberSaint
252
San Antonio, Texas
Aug 4, 2010
  • Aug 4, 2010
Hello all,
I have a 260cid/4spd generator car. The battery is very good in it. After I drive it and its warm, and I go to restart it, it seems like the battery is drained and it cranks very slowly. I was thinking that this could be a starter solinoid. Can someone please help me out. No drain on battery and electical system is original.
Dale in San Antonio
mustangmutt
339
El Paso, TX
Aug 4, 2010
  • Aug 4, 2010
Is the generator working properly? Does it only do it when the engine is hot? It sounds as if the starter is suffering from Heatsoak. Take it to a shop that has a VAT40 or equivalent machine that can test the charging and starting systems on the car. The starter should not draw much more than 100 amps and the battery voltage should not drop below 9.5 while cranking.
SyberSaint
252
San Antonio, Texas
Aug 4, 2010
  • Aug 4, 2010
It only does it when the engine is hot, and I am running headers on the car. Maybe grounds are not grounded correctly?
Thank you for your help.
Dale
golf4283
1,253
Orland Park, Illinois
Aug 4, 2010
  • Aug 4, 2010
This sounds to me like heat soak. You can buy those sleeves for over your starter but if I were you I would remove the header and use some header wrap around the area near the starter. That's what I did to protect my cable clutch from melting.
PoppyMod
617
Severna Park, MD
Aug 5, 2010
  • Aug 5, 2010
Hi,
I'll add, if "heat soak" is suspected after running the other tests, you might consider installing a small base starter. It provides a little more distance between it and those headers. The ceramic coatings are very good at keeping the heat in those headers, as well, and functional at the same time.
Also, adding a insulating wrap to the header in that area may help. But, I'm not a fan of wrap with the discovery of ceramic coatings. I've been running a small base starter, with my ceramic coated TRI-Ys for a couple of years without any heat soak related problems.
Good Luck!
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
