  • SN95 4.6L Mustang Tech
slow dropping idle?need help
  • Thread starter Thread starter TNstanggurl
  • Start date Start date May 28, 2004
T
TNstanggurl
153
TN
May 28, 2004
  • May 28, 2004
Ok here the deal. Today we got a 97 gt 5-speed, autumn orange,104k from and auction. Best part about it is we got it for 3k! Clutch is awsome and the thing is f##kin fast. I dont think it is stock, to fast to be, but I don't know if anything is done to it because we got it at the auction. But anyways heres the deal. It takes the rpms a good 5 or 10 sec. to drop down to 1k. Isn't 1k to high to idle at. I was just wondering if this could be a vacuum leak or somthing or could it possibly have a cam and not been tuned for it. I am new to the performance side of the 4.6 so any info on the motor/car would be great. Thanx,Wes P.S. This is my girlfriends screen name
KaPPaBaLL
1,326
BAYAREA
May 28, 2004
  • May 28, 2004
what do you mean it takes a good 5-10 seconds to drop to idle? is this after you romp on it or after you start it up or what?
Yes, your idle should be at around 650-750. After you car warms up see what the idle is. If you want to look for any vacuum leaks hold a lit cigarette around the engine bay. If the smoke goes to one area, you have a leak.
About your cams. More than likely if it does not have a mild to mediocre lope you probably have stock cams.
oh, get a tune up. flush the tranny fluid, flush radiator fluid, engine oil, and switch plugs.
T
TNstanggurl
153
TN
May 28, 2004
  • May 28, 2004
it idles like that all the time. when you stop or it is just sitting there it will eventually drop. Haven't really listened for a lope, been havin to much fun floorin it.
KaPPaBaLL
1,326
BAYAREA
May 28, 2004
  • May 28, 2004
you'll definitely know if you have aftermarket cams. so it will never go below 1000rpm correct? First off, try going to autozone if there were any codes thrown in the first place. Record those codes and post them back up here. If there are no codes, try resetting the computer disconnecting the negative terminal on your battery for 10minutes and reconnecting it. Let the car idle for 5 minutes with the a/c off. Then another 5minutes with the a/c on. See if that helps.
if that doesn't help. Try to buy a new IAC at a local autopart store that carries motorcraft parts. Ford charges a grip so might want to make that your last resort (paparoach).
T
TNstanggurl
153
TN
May 28, 2004
  • May 28, 2004
Yeah, the rpms never go below 1k, I realy appriciate the help, Thanx,Wes
Blev
1,295
So. Cal. V-Town
May 28, 2004
  • May 28, 2004
Do the copper cap mod and that will fix the problem. RPM's drop nicely after that.
H
hotstang
602
Tennessee
May 28, 2004
  • May 28, 2004
TNStangGurl,
What part of TN are you in?
T
TNstanggurl
153
TN
May 28, 2004
  • May 28, 2004
hendersonville, u?
KaPPaBaLL
1,326
BAYAREA
May 28, 2004
  • May 28, 2004
TNstanggurl said:
hendersonville, u?
you better hurry and tell him you're not a girl.. lol
T
TNstanggurl
153
TN
May 28, 2004
#10
  • May 28, 2004
  • #10
LOL, Hey on that copper cap, do you put it between the air intake and the black box, or the black box and actual aluminum intake? Oh, I think it might have cams,do the stock cams run real smooth or do they have a slight lope to them, because we were sittin in the line at DQ and at 1k it had a rough idle,not like a big ol lope but i think if it were at the stock idle it would have an even rougher idle. Thanx,Wes
Blev
1,295
So. Cal. V-Town
May 29, 2004
#11
  • May 29, 2004
  • #11
Between the black box and the plenum. Make sure you put it in backwards or you will have a hard time trying to take it out. I can take a picture and post it if your still not sure.
T
TNstanggurl
153
TN
May 30, 2004
#12
  • May 30, 2004
  • #12
Hey, I did it today and it worked but I could tell a difference in the power the car had so i took it out.
Blev
1,295
So. Cal. V-Town
May 30, 2004
#13
  • May 30, 2004
  • #13
??you lost HP??
I don't see how you would lose HP. I mean, for you to be able to notice it, you would have had to lose at least 10 - 20 hp. I could be way off, but that just doesn't sound right. Hmmmm..... time for a new thread.
T
TNstanggurl
153
TN
May 30, 2004
#14
  • May 30, 2004
  • #14
Maybe its all in my head but I could feel a slight difference and I didnt like it. I am gonna drill a bigger hole and see what happens.
KaPPaBaLL
1,326
BAYAREA
May 30, 2004
#15
  • May 30, 2004
  • #15
everyone knows that autumn color cars are no good in the summer.
03-s281
421
Stangville,TN
May 30, 2004
#16
  • May 30, 2004
  • #16
TNstanggurl said:
hendersonville, u?
get on tennesspeed.net and ask around, somebody may have owned it or
know somebody that did. I'm only about a 20 min drive from h-ville.
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
J
89 2.3 LX running rich, hesitation on acceleration, high and hanging idle Help!
  • jpstucky
  • Jun 13, 2023
  • 2.3L (N/A & Turbo) Tech
3K
2.3L (N/A & Turbo) Tech Jun 15, 2023
jpstucky
J
Nice Sn95. 100k miles. Heirloom. Garage kept. We need some help
  • Jacobn4056.
  • Jan 17, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2024
90sickfox
T
Engine Need help with cold start
  • TheCapt.Awesome
  • Jan 18, 2023
  • Fox Engine Swaparoo
4K
Fox Engine Swaparoo Mar 14, 2023
Mr.Kelley
HELP! New fox owner power question
  • Ramennoodles77
  • Jul 17, 2020
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2020
Mustang5L5
