  • SN95 4.6L Mustang Tech
Sludge in Engine...Gotta Replace?
  • Thread starter Thread starter upstech
  • Start date Start date Mar 31, 2005
First Prev 2 of 2
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Apr 1, 2005
#21
  • Apr 1, 2005
  • #21
what oil/filter were you using?
wanta5.0
546
#22
  • Apr 1, 2005
  • #22
Don't replace the motor you can get it out. I had a 3.1 V6 that started running hot so I figured it was leaking coolant so I added more water and I never did see any leaks so it ran ok for a while then it started running hot again and all of the coolant and water went into the motor. Talk about SLUDGE!!!!!!!!!!! That **** was thick. Let it all drain out and then poured diesel in the oil filler until it was pure diesel then took the heads off and cleaned them up and fixed the the problem and put it all back together and 20k+ miles later it still runs great. Has over 100k miles too.
R
rjstaaf
1,310
Somewhere
Apr 1, 2005
#23
  • Apr 1, 2005
  • #23
Go to www.auto-rx.com. It is specially for breaking down sludge. They have forums there were you can ask questions or you can visit the Additives forum at www.bobistheoilguy.com. The stuff does work!
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=forum;f=5
W
Will Smith
191
Cape Coral, FL
Apr 1, 2005
#24
  • Apr 1, 2005
  • #24
sounds like maybe ur main bearings are shot. have them look at them. I know i had the same problem as far as the ticking was concerned but i bet it could be a problem.
First Prev 2 of 2
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
M
  • mnky99
  • Sep 5, 2025
mnky99
M
4.6 question for those in the know....
  • LILCBRA
  • Aug 30, 2024
2K
2005 - 2014 S-197 Mustang -General/Talk- Sep 4, 2024
Adieu
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
J
1995 Mustang V6 - Cyl #3 Misfire - Help!
  • JasonBlue
  • Aug 30, 2023
  • 1994 - 1995 Specific Tech
5K
1994 - 1995 Specific Tech Oct 20, 2023
def_68
D
