Installing long tubes and an offroad h pipe this weekend, so I ordered a smog pump delete, my question is, is this a direct bolt in setup? Remove the smog pump, remove the old exhaust, and install? Or am I missing anything else? Thanks!
Most of the nation does not have emission testing.Emissions testing won't fail you if you remove the smog pump? I know these cars are getting old enough to be considered classic but don't they still require smog testing?
I wouldn't even bother with the smog pump delete pulley. Just use a shorter belt and reroute it. like this.![]()
