smog pump delete?
  • Thread starter Thread starter 88GT4u2nv
  • Start date Start date Jun 15, 2005
88GT4u2nv
60
Wa
Jun 15, 2005
  • Jun 15, 2005
my smog pump is making all sorts of noise, and i dont have emissions where im at, is there a way of just running without it, besides buying a delete bracket?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 15, 2005
  • Jun 15, 2005
Remove the pump and run a shorter belt. Then remove the lines all the way back to the rear of the heads. Then stand back and see how much more room you have.
_jb_
808
Michigan, Berrien County
Jun 15, 2005
  • Jun 15, 2005
http://www.fordmuscle.com/archives/2000/02/quicktips/index.shtml
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jun 15, 2005
  • Jun 15, 2005
You dont need in anyway if your cats are off.
RC
5.0 Nostalgia
904
CT
Jun 15, 2005
  • Jun 15, 2005
You can run the shorter belt as 90mustanggt said. Then just take all the emissions stuff off. A lot of people cut the pipe that leads to the head but I left mine on and capped it. You can also cap the part of your exhaust midpipe where the smog hose attached. I cleans up the engine bay. I kept all of my stuff. Now I have emissions and have to put it back on.
Fishhawk
281
Michigan City, Indiana
Jun 15, 2005
  • Jun 15, 2005
Instead of cutting or capping off the thermactor tubes in the back of your heads get a couple of these.
http://store.summitracing.com/defau...ults=false&N=0&target=egnsearch.asp&x=15&y=10
Curse
791
El Paso, TX
Jun 15, 2005
  • Jun 15, 2005
Damn where were you when I need these things I ended up just running a bolt with some thread sealer, turned out ok.
bobbyd
312
San Antonio/Los Angeles
Jun 15, 2005
  • Jun 15, 2005
aight guys i just put my hedders a few weeks ago and didnt put that one smog tube that goes to the midpipe. so if i was to get a shorter belt and not connect it to the smog pulley there will be no more smell and reason to put the tube that goes to the midpipe or will the smell still be there?
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
