smog pump delete
You will have a bad exhaust leak. Air from the smog pump enters the heads through those holes and eventually into the exhaust ports to provide oxygen to burn unburned fuel leftover from the combustion process.
Most speed shops can get you a special plug that is actually threaded on the inside so that you can use the hole for something.....like an extra ground strap. I don't know how else to describe the plugs...they are common.
