Smog Pump Question!!!
A smog delete kit would work. Or get creative with belt routing (search in here for what works).
Good luck.
Yup, just remove it and use a smaller belt. IMO all these delete kits are useless. If you want to remove something, just remove it, get a smaller belt and re-route it.
When I built my engine I didn't bother putting the smog pump back on, so once everything else was on I used a string, held the tensioner about 3/4 of the way "tight", ran the string and measured it. A friend of mine has some underdrive and overdrive pulleys, but he has the same amount of pulleys as I do. We have two different belt routes, but it accomplishes the same thing.
