smog pump removal question
  • Thread starter Thread starter fox-gt
  • Start date Start date Mar 6, 2007
fox-gt
204
TN
Mar 6, 2007
  • Mar 6, 2007
I spent a few days searching on pros and cons of removing the smog pump. Right now mine is hooked up and pumping air into nothing. I do have cats on my H-pipe. Some threads have said running cats without the extra O2 will burn them up (or clog them). The air connection in my H-pipe is currently plugged and I did pass emissions, but I don't want to damage the cats. My smog pump has started making an irritating whining noise. I don't know if I should replace it and hook it back up to the H-Pipe or go with a delete kit. The car is my daily driver.
Any help or thoughts would be appreciated.
superhuaman
907
Harrisburg, PA
Mar 6, 2007
  • Mar 6, 2007
I believe that what you said about the cats not getting air is true, for the FACTORY cats. I have heard that aftermarket "hi-flow" cats will live without air, and they are more efficent, since theres only one cat for each bank, not 3. They have the air tubes just to comply with emissions, but should pass smog without. Personally, I would delete everything A.I.R. related except for the TAB/TAD solenoids (required to stay plugged in to avoid codes).
As for the belt issue, do a search. I can't remember what size I used (with A/C & P/S) but I can tell you how to route it.
HISSIN50
34
129
Mar 6, 2007
  • Mar 6, 2007
Good info above. I'd say that the safe road is to get a new pump (or try to clean yours up - I have a pic or two of the inside of one if interested) and hook it up as is OEM (for quicker light-off, and O2 supplementation).
BUT, if you've been running for a bit on these cats with no pump (it sounds like the cats are not OEM), then I guess there's no big harm in continuing to run without the extra air injection, huh.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 6, 2007
  • Mar 6, 2007
If the cats have an air tube, it is there because the catalyst needs it for the catalytic reaction. Without the extra air, the cats will lose efficiency and clog. The computer instructs the smog pump to dump all the air output at WOT (Wide Open Throttle), so the 2-4 HP you save isn't worth the effort.
fox-gt
204
TN
Mar 6, 2007
  • Mar 6, 2007
Makes sense. I will get a new smog pump and hook it back up to the H-pipe.
Thanks everyone.
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Resolved Three way cat converters..?
  • PonyGTrider
  • Nov 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
PonyGTrider
L
Exhaust 95 gt pypes catted x pipe
  • Lx5.0fiend
  • Aug 22, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 18, 2025
revhead347
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
