smog pump
  • Thread starter Thread starter cheddarbacon
  • Start date Start date May 5, 2005
C
cheddarbacon
82
  • May 5, 2005
Hey guys ive been reading some threds on the smog pump delete i already delted my smog awhil ago but i was just reading the treads and there saying there are 2 hole you need to plug up coming out of the heads. can anyone describe were these head holes are that would be great thx
and if anyone can answer this it would be great were the smog use to be there is a little black box just under were the smog use to be.
C
cheddarbacon
82
  • May 5, 2005
ello?
hello?
MrKwik
1,008
Kansas City, Kansas
May 5, 2005
  • May 5, 2005
they are at the back of the head facing the firewall. They are the biggist hole at the outside corners. There is a pipe that runs between them. As I have discovered, you can plug them with a 9/16" bolt and washer but it has to be cut down to like 3/4"
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 5, 2005
  • May 5, 2005
. If you are going to delete the smog pump then you will need a threaded insert known as a thermactor plug. They screw into the back and front of your heads. Put silicone on the threads to prevent any exhaust leak when installing them. The thermactor plugs you will use for the front (same as back) will go to make the head holes smaller so the accessories can bolt up like your power steering stud and one of your bigger alternator bolts that go through you alternator bracket. The back thermactor plugs you will use just block off and delete the smog equipment’s previous hookups. You can get them at a Ford Dealership - part # F4ZZ-6E086-A or you can buy some from Summitracing - part # TFS-51400265 and they run anywhere from $3 to $12 dollars from what I have seen. Summit has them cheaper.
BaXTeR3221
917
Orange County, NY
May 5, 2005
  • May 5, 2005
On the back i just took off the pipe, flipped it around and bolted it back up again. Seems to have worked pretty well.
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Smog pump bypass?
  • PvolkStang
  • Apr 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
nickyb
