noticed this last night at a drive thru that took forever.
Its not pumping smoke or anything it just kinda "floats" threw the dash/vents fairly light but noticable? Really only noticed it after stopped for a good while.
I parked the car and ate in the lot and popped the hood to make sure it was not a fire or some stupid thing.
Its not leaking anti-freeze on the floor (heater core), its not an elec. fire or anything (that I can tell), does not smell like exh., oil , or antifreeze. It kinda has a smoke funk to it though just cant place it/its not very strong.
No oil leaks or coolant leaks under the hood, no volt spikes or drains, not running hot, and has great oil press with 70-75 startup, high20's to low 30's at warmed up idle and 50+ just cruising...with 60+ going WOT.
I am thinking either the heater core is "starting" to let go...SLOWLY. light clutch/maybe some oil from just sitting (very slight rear main leak...very light). It also may be the factory 4 cat H-pipe...like a little critter stuck in there since it has been 3 mo or so since it had ran.
Any other ideas? Going to try and get the car smog tested Tues. after work dont want to find out there and freak out the testers.
. Sorry I know this was useless..
