smoking
  • Thread starter Thread starter Rushman04
  • Start date Start date Aug 18, 2005
R
Rushman04
42
  • Aug 18, 2005
alirght iam a new proud owner of a 1986 mustang gt with t tops. I have msd 6a ingintion box and blaster coil. I put new wires in and i still got a miss fire. The other day i had to reseal the valve covers and put in a new throttle body gasket. I started it up and it ran for 3 mins with white smoke coming out then the motor just died. I tryed starting it up but its just cranks and tries to fire but don't get a good fire. Any suggestions would help me out alot.
The Shape
2,224
East ARKANSAS Delta
Aug 18, 2005
  • Aug 18, 2005
Check that throttle body gasket. If it doesn't seal well between the TB and the EGR spacer it will let coolant into the intake. Which will cause the white smoke.
ninety15.0
1,336
  • Aug 18, 2005
With a stock motor the coolant runs through the EGR spacer and like the shape said if you dont have a good seal with that new gasket thats the culprit. Also i would double check the firing order...good luck
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Fuel 1990 mustang gt 5.0 no ground signal to fire injectors
  • brandyn200
  • Sep 5, 2025
Fox 5.0 Mustang Tech Sep 6, 2025
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
