Smoking
Makdaddymac
323
orlando
Smoking,MPG HELP
My car smoke from the manifold if i take it upto 4k-4.5k, but if i drive it under3k it doesnt do anything, i can see that there is oil leaking from the lower manifold(im fixing that).
Is the leak my only problem. IM concerned its something else cause(i dont recall if this is new or not) but around the tb and top intake manifld right were the two connect, is discoloration almost completely around the connection as if they were wet,possibly GAS!? Any clues
Also my MPG isnt that great maybe around 12-15 which isnt ****ty but defintely not as good as can can be. Besides the tune up basics would a faulty 02sens send a CODE/CHECK LIGHT on these 5.0's or do they just go bad and you have to replace them..
If they are the stock valve cover gaskets, dont make the mistake of throwing them away if they are not damaged. Just clean them up and re-use them. They will be metal, covered in rubber if they are stock. Keep them, they are the best.
Install a new PCV valve and a new screen (under it) while you are in there.
