sn 93 timing
  • Thread starter Thread starter fast50hz
  • Start date Start date Nov 6, 2005
F
fast50hz
26
  • Nov 6, 2005
My brothers car is an 88 mustang gt 5 speed. it has a paxton sn93 supercharger with a upr boost pipe. Headers and orx pipe.
Everything else is basically stock.
What should the initial base timing be set at?
I know how to set the timing etc.
I just need to know the base timing. It seems to run good at 10*.
Would it be safe to keep it at this?
thanks for the help
notchback
1,950
St Clair Shores MI
Nov 6, 2005
  • Nov 6, 2005
if he is making 6-7 lbs of boost and it's hot out...yes 10* is about it
if it gets cooler out 75* and below....you could bump to about 12* and possibly, if only 6 lbs maybe even 14* but it would have to really cool out and no humidity.
best way to get the best timing is to run at the track, then up the timing by 2* and check mph...not et...mph try 10-12-14 and wherever it had the best mph is best for those conditions.
of course if it pings...get out and back it off
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
