sn-95 8.8 rear in 67 conversion
Do you know what size u-joints are on your stock drive shaft? I think that the length for a 9" DS is right for an 8.8. You will need a 50" DS with 1330 u-joints and the end piece that bolts to the 8.8 pinion flange. I used both the front yoke and the companion flange from a 95 and had a DS built. It would be good if the stock DS would work. There may be a conversion u-joint is you have 1310 u-joints.
