I have had some rubbing issues since converting to sn95 brakes. Someone on another thread had suggested that my combo was the problem. I would like to know if what I did several years ago is unusual.
Front
94 uprights
17x9 cobras with 24mm offset (from AFS)
255 Tires
I did have to hammer out the outer fender lip quite a bit to prevent rubbing. The way it is now, I will only rub if I hit a bump in a hard corner. There is some very slight rubbing on the inner fender apron, but it is only enough to make a clean spot. I am not worried about it.
Rear
95 rear end
95 31 spline axles
17x9 cobra with 36mm offset (from AFS)
275 Tires
I did not have to hammer the outer fenders too much when I had 255s in the back. I have no clearance issues on the inside. I still have the quads in place and did not have to turn them over. I have about .5" clearance between the tires and quads.
Is this different than what most people do when they convert their brakes. Are my rubbing issues due to having the wrong parts somewhere? If I can change out some parts to improve tire clearance, that would be nice.
I appreciate the help guys
jason
Front
94 uprights
255 Tires
Rear
95 rear end
95 31 spline axles
275 Tires
jason
...I think the 275s are 2 big with the sn95 axels
