Brakes Sn95 rear brake conversation
I just did the sn95 rear disc conversion on my fox. As you can see the brake like bolt is hitting the inside of the beadlock. Do they make a flush mount bolt or would I be able to grind enough to make it clear ?
They do make low-profile banjo bolts, but some guys have just taken a grinder to the top of the bolt and shaved it down very slightly.
Those rear Sn95 calipers used two different thread pitches. Some are 10mm x 1.5 thread pitch, and some are 3/8"-24. You'll have to pull one out to see what you have if you want to try purchasing new bolts.
Reactions: Mald103
