P Paulywalnuts446 New Member Oct 17, 2004 84 0 0 Jun 13, 2005 #1 Jun 13, 2005 #1 if i was going to use a sn95 spindle in a fox do i have to use strut for that year or just stay with the ones for a fox?
ALMOSTFINISHED Member Jan 8, 2004 315 0 17 Westchester County NY Jun 13, 2005 #2 Jun 13, 2005 #2 You can use the fox strut. I think it is also possible to swap to sn struts/springs but its not manditory. You will need the ball joint spacer or stack of washers. Nick
Mustang Yawie Founding Member Jul 21, 2002 281 14 28 Rialto CA Jun 13, 2005 #3 Jun 13, 2005 #3 I belive that the 94-95 struts where a bit longer so its best to use the fox style struts
Shakerhood 20+ Year Stangneter Oct 28, 2004 3,361 211 114 Ohio Jun 14, 2005 #4 Jun 14, 2005 #4 The SN95 Spindles have a slightly lower mount for the struts, so either struts will work.
