snapping from the distrubutor?
88-5.0mustang
last night when i was out in my car i noticed their was a snapping sound comming from underneath the engine bay when i was idling at a light. So i pulled into a parking lot popped the hood and i listened carefully. It sounds like its arching in the distrubutor.. almost like when it snaps to clear the plug gap.. the cap and rotor are msd and are fairly new. I inspected them closely and it did'nt show any signs of arching. I talked to a buddy of mine and he said the TFI modules like to go and that could be whats causing the snapping noise? just wondering if anyone else has any input on it
Thanks
Kevin
Is engine performance affected at all?
If so, a broken rotor or cap with a crack in it can do that.
Is there any mainshaft play in the dizzy?
The TFI sends a ground pulse to the coil when spark is needed. I cant figure out how it would cause noises like that, but that doesnt mean it's not possible.
Good luck.
no the engine performance is'nt effected it seems to still run nice and strong.. i'll pull the cap off and recheck it to make sure their is no crack in it and i think their is a little play in the main shaft.. but not much.. i had a distributor before this one and it had caused it to missfire in the top end do to vibration
Kevin, my best guess would still be some sort of spark leak, though it usually creates a miss or power loss. If you watch under the hood in the dark, can you see any seepage? Having spark seep into the metal shield adjacent the spark plug wire boot is not uncommon and can cause popping noise. That's nowhere near where you noted the noise but it's one of the first places I check for a leak.
Otherwise, I don't have any great ideas.
Good luck.
