So how much difference do you think weight makes?
Hizzle
51
Fort Carson, CO
I'd like to drop some more weight but not mess with any structural integrity. I have pulled the smog, equipment, went manual steering rack, no A/C, no backseat, and i pulled the insulation out from behind the interior trim panels. It was a bit musty and the sound doesn't bother me. The car also doesn't get driven that much. What have you guys done to shave some weight by either removing other items or replacing some with lighter pieces but not messing with the structural integrity of the vehicle? How much difference do you think shaving weight makes as far as performance? I know a lot of it comes down to weight distribution.
From what I've heard, each 100 lbs = 15 HP.
Aluminum heads will free up a pretty good chunk of weight, as will an aftermarket K-member. Taking weight off of the nose will help overall handling.
You want a HP to weight ratio of 10:1 or lower...the lower, the better in terms of performance.
Good luck :nice:
gonna wait on the heads until i build my 347. I don't want to mess with the '86 block and heads/cam due to the compression. It sounds like I need valve reliefs to really run anything. It has E7 heads on it now. The guy put them on not too long before I bought it. The car only has 87,000 miles on it so it should still have some life left in it until I can build the other one.
Theres guys over on the corral who are running 12's with a stock motor and gears.. How? They did crazy ass weight reduction..
A good friend of mine went 12.77 @ 105 on a stock motored notch. 3.73s, suspension, MAF, pulleys, exhaust and tires. His wasn't gutted, but did come in right under or around 3000 lbs with him driving it.
Most say 100 lbs is a 10th, and that is a decent round about. It changes with how fast your going and where the 100 lbs comes off.
There's a hatch belonging to one of the MM+FF guys that runs 11.90s and only dynos at 300hp at the wheels. The key is being able to drop enough weight that you can safely add weight back in where you want it to aid in weight transfer. That plus slicks plus driving it with no mercy equals amazing time slips.
Good luck :nice:
A HP to weight ratio of 10:1?
350hp 35lb car?
I think you meant Weight to hp ratio!
