66HertzClone said:
The vacuum hoses connected to "ported vacuum switches" that were threaded into the water outlet (thermostat housing). These were used to turn on and off the operation of the vacuum advance based upon engine temps. Granted they could have and probably did turn off other items but vacuum advance was the most common, EGR and other came later.
Clever! So when the engine is cold there is more vacum advance.... Do you happen to know what years/engines this was used on?
66HertzClone said:
I will be going thru the same thing this winter, I am going to install this kit,
http://www.mass-floefi.com/index.html
The mass-flow kits are definately nice! Although too rich for me unfortunately... and I don't like the fact that you cannot tune it. However, this may be considered an advantage by others.
I'm going to use the Megasquirt ECU. It's alot more difficult as you have to figure everything out on your own (which sensors, injectors, etc). BUT it's all free..the plans/schematic is published and ment so that you literally build your own ECU. Or you can find them pre-built for about $100 more than what it would cost you yourself. Asside from the price, the other main advantage is that it's 100% programmable. You can use any sensors, or combination of fuel injection equipment...you just have to program the ECU to accept it. It's basically a computer that is programmed to do EFI. It's so flexible it can be used on anything from a 16cyln aircraft engine right down to a single cyln two-stroke dirtbike.
One I have the basic installation done, I plan to eventually controll the nitrous system via the ECU.
If your a handy guy who isn't afraid of electical wiring, I'd look into the MegaSquirt ECU.
66HertzClone said:
I am trying now to figure out the best way to add the required pump and the return line. this kit was recommended to me. But I'm pretty sure I can come up with something that is a lot less expensive and won't interfere with the floor of the trunk.
http://www.thedetailzone.com/Tanks Fuel Pump Install.htm
You have a few options here. Personally I'd try it 1st using the stock pickup. If you find that it's sucking air and is a real pain..you can always convert later. From what I understand it's not usually a problem until you get down to about 1/4 of a tank.
The other option is a surge tank. Basically what you do is keep the stock pump and have it fill a small containter. Then connect your high pressure pump to this container. Running 2 pumps kinda sucks, but it's a heck of alot cheaper and easier to do..not to mention you can keep your tank stock. Do a google search on "surge tank" for more info.
Personally, I plan on using the stock pickup...if it's a problem I'll do something about it later. For a return line I plan on removing the factory fuel sender unit/pickup and then drilling a hole in it and welding on a fitting. The other common thing to do is to tap into the rubber fuel filler hose.
66HertzClone said:
Here is a link to some photos of my car.
http://www.cardomain.com/ride/597572
Beautiful looking car! You can tell that you really put alot of time into it!
