I know what those codes mean and I know the 98 is a result of the 66. I'm sorry to say I have not been able to get my hands on a spare ECM (A9L) anywhere. Nobody has one. Now, I am constantly getting codes 66 and 98 on KOER. The computer appears to be ignoring any output from the MAF sensor to the SIG pin. Everything check out correctly. I tore through all the wiring between the sensor an d the computer. I beat on it.. Moved it all around .. shook it. Tested it at the computer directly. Ran Voltage tests and resistance checks.
90% of the time the engine starts with the Check Engine light on now. It was never like this before. And it runs pretty good with just a bit of throttle lag. But, every 4 or 5 engine starts, it will start up with the CE light OFF and then suddenly the engine is running so bad it backfires and will stall out. Then I re start it and suddenly the CE light turns on and the engine runs fine. While the engine is running now, I can unplug the MAF sensor and it wont change the way it is running. No effect in anything, Plug it back in ... no effect. I can jump the REF and SIG pins on the MAF plug with a low ohm resistor..nothing happens. Jump it directly, nothing happens.
Resistance between SIG and GND, while the engine is off and key off, it is a FLAT 50.0K ohms ( this is with the sensor unplugged). As soon as I turn the key on, the resistance drops to 39.8K ohms. Same thing when the engine is started. If I plug the sensor in while the engine is running then leave it for a half minute , then unplug it and test, the resistance goes to from 59k to 61k, sort of fluctuating a bit but only while the engine is running. As soon as the key gets shut off, the resistance drops right down to a flat 50.0k ohms. REF is at 5.5V. red hot positive wire at battery voltage.
The computer seems to be ignoring the MAF signal now. All the connections check out as they SHOULD be. ANd I have tried other MAF sensors with no difference. It seems, that the computer WILL try to use the MAF sensor every few engine starts, BUT when it does it sputters backfires and stalls out.
Can ANYONE test their MAF and tell me what they get on their SIG to GND resistance at the MAF connector pins with it unplugged AND key OFF? The harness plug , NOT the MAF sensor itself. My only other guess with this is that the computer has crapped out and is only running in a pre-programmed mode. Maybe it is damaged.
How do you removed the computer ? I removed the bottom bolt and unplug the computer harness but I can't budge the computer. Do I have to remove the dashboard for this?
Thank you all in advance.. and for dealing with my frustrations...... lol
