SuperStang83
Loosen your radiator cap to take pressure off the system then you won't lose near as much when you pull off the hoses. If you leave the cap on it will shoot antifreeze everywhere!
You make it sound like he's working on the fuel or A/C refrigerant systems rather than the coolant system...
just bypass the thing and buy a damn jacket. builds character
I thought the same thing the first time I bought one. Just a cheap, simple little part, yet it can be so demanding if you aren't ready for the job. lollol....got the heater core...such a lil thing that causes alot of problems...
I think the toughest part for me was getting the heater core out of the evaporator box, but putting it back in was easy.
If you got an FRPP bracket, most parts places should have a factory non-A/C belt listing in there. Can't remember the exact length/part number right off hand, though, sorry...
You could always just cut the black box with a Dremel ... but be prepared for a bunch of dudes on here to start yelling at you about doing that.![]()
I agree with Darkwriter77, theres not much pressure unless its realy hot, plus he has a leak so it's most likely not building any pressure to start with.
Id replace the hoses on the outside of the firewall while its apart.
Theyre less than $10 each.
You done with this yet?
