OK, my little $500 project car has an AOD which shifts very firm (tire barking 2nd gear shift) but it shifts into third WAY too soon, and also has a shudder that I think might be the converter. I have a bell housing, a T-5, pedals, wiring harness, driveshaft, aluminum quadrant and even the shifter "hump" for the floor pan. All I need is the clutch/flywheel, and the clutch cable. I have done the swap before, so that's no big deal but the trans I have I bought used and was told its a "good shifting no issue" trans. I would hate to go through all the hassle of swapping everything over and then find out the trans is no good. The trans is out of a 92 5.0. Should I roll the dice? Is there anything I can check without tearing the trans down to give me a little more piece of mind that its good? It spins smooth and seems to not have excessive endplay.
Thanks
Chris
Thanks
Chris
